python hou.node.moveToGoodPosition
   11334   5   0
I find that with this bit of code, if I'm moving a network, that the nodes almost never end up in a good position.
I'm moving the nodes one at a time right now. Are there any tricks for moving a whole network?
cheers,
-j
Ctl-a selects all the nodes, then you can move them. You can also right click on a node and ‘select input’.
J.C.
John Coldrick
Heh, apologies for being unclear…
I have a python script
for n in nodes:
n.moveToGoodPosition(move_outputs=False,move_inputs=False, relative_to_inputs=True)
As you can see, I tried playing with some of the options with no real sucess. Is there a better way to do this?
cheers,
-j
Ah, yes, I see…am I not reading subjects again?
Sorry, never touched that - I'm just guessing but I would imagine ‘good position’ means whatever ‘l’ does when you hit it in the interface…but maybe someone can jump in who's actually used it.
J.C.
John Coldrick
Hmmm, that's a good point JC. Using the ‘l’ key you can transfrom a selection of nodes all relative to each other…
I imagine that this method (multiple nodes at once) hasn't made it to hython yet?
cheers,
-j
I get nice results using layoutChildren()
http://www.sidefx.com/docs/houdini/hom/hou/Node.html [www.sidefx.com]
Try it out.
