I've tried installing both 64bit binaries (ie Debian 64-bit Linux lenny and etch) and the in-built help browser fails to load the help in both versions. There are some dynamic
linker errors in the shell:
> houdini
/usr/lib/firefox-3.0.1/firefox: symbol lookup error: /usr/lib/libgdk-x11-2.0.so.0: undefined symbol: g_once_init_enter_impl
./hbrowser-bin: symbol lookup error: /usr/lib/libgdk-x11-2.0.so.0: undefined symbol: g_once_init_enter_impl
Are there some extra packages I might need to install? The rest of houdini seems to
work fine, but its not much fun without help.
Extra info:
The installers I tried:
houdini-9.5.220-linux_x86_64_gcc4.1.tar.gz
houdini-9.5.220-linux_x86_64_gcc4.2.tar.gz
> uname -a
Linux rees 2.6.24-19-generic #1 SMP Wed Aug 20 17:53:40 UTC 2008 x86_64 GNU/Linux
> lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 8.04.1
Release: 8.04
Codename: hardy
hbrowser problems on ubuntu 8.04 x86_64
7931 6 0-
- rhyshawkins
- 4 posts
- Alanw
- 320 posts
Try using “ldd” on hbrowser-bin to see which search paths it's using to find your libs. Perhaps Firefox as well.
ldd ./hbrowser-bin
from within $HFS/bin
Do you know if your Firefox is 32 or 64 bit?
On my Ubuntu 64 machine I use 32 bit Firefox 3 and I had to customize it quite a bit. There were multiple 32 bit GTK related libraries that Ubuntu just doesn't offer in it's repositories, but I eventually found what I needed in some CentOS rpm's.
ldd ./hbrowser-bin
- rhyshawkins
- 4 posts
I have fixed this now. The ldd output (below) showed that hbrowser was picking up
the system libgdk-x11 and the libgobject from $HFS/dsolib which were obviously not
compatible. I deleted libg* from the dsolib directory and everything seems to work
now. I wonder whether this is an installer bug that installed these files unnecessarily?
I'm happy to provide extra information to help resolve this.
Firefox version:
Mozilla/5.0 (X11; U; Linux x86_64; en-US; rv:1.9.0.1) Gecko/2008072820 Firefox/3.0.1
Here is the ldd for hbrowser-bin:
linux-vdso.so.1 => (0x00007fff897fe000)
libgtk-x11-2.0.so.0 => /usr/lib/libgtk-x11-2.0.so.0 (0x00007fbc80f6e000)
libgdk-x11-2.0.so.0 => /usr/lib/libgdk-x11-2.0.so.0 (0x00007fbc80cd4000)
libatk-1.0.so.0 => /usr/lib/libatk-1.0.so.0 (0x00007fbc80ab4000)
libgdk_pixbuf-2.0.so.0 => /usr/lib/libgdk_pixbuf-2.0.so.0 (0x00007fbc8089a000)
libpangocairo-1.0.so.0 => /usr/lib/libpangocairo-1.0.so.0 (0x00007fbc8068f000)
libfontconfig.so.1 => /usr/lib/libfontconfig.so.1 (0x00007fbc8045e000)
libXext.so.6 => /usr/lib/libXext.so.6 (0x00007fbc8024d000)
libXrender.so.1 => /usr/lib/libXrender.so.1 (0x00007fbc80044000)
libXinerama.so.1 => /usr/lib/libXinerama.so.1 (0x00007fbc7fe42000)
libXi.so.6 => /usr/lib/libXi.so.6 (0x00007fbc7fc39000)
libXrandr.so.2 => /usr/lib/libXrandr.so.2 (0x00007fbc7fa32000)
libXcursor.so.1 => /usr/lib/libXcursor.so.1 (0x00007fbc7f828000)
libXfixes.so.3 => /usr/lib/libXfixes.so.3 (0x00007fbc7f623000)
libpango-1.0.so.0 => /usr/lib/libpango-1.0.so.0 (0x00007fbc7f3df000)
libcairo.so.2 => /usr/lib/libcairo.so.2 (0x00007fbc7f174000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x00007fbc7ee71000)
libgobject-2.0.so.0 => /opt/hfs9.5.220/dsolib/libgobject-2.0.so.0 (0x00007fbc815fa000)
libgmodule-2.0.so.0 => /opt/hfs9.5.220/dsolib/libgmodule-2.0.so.0 (0x00007fbc7ed6e000)
libdl.so.2 => /lib/libdl.so.2 (0x00007fbc7eb6a000)
libglib-2.0.so.0 => /opt/hfs9.5.220/dsolib/libglib-2.0.so.0 (0x00007fbc7e9d8000)
libgtkembedmoz.so => /opt/hfs9.5.220/mozilla/libgtkembedmoz.so (0x00007fbc7e897000)
libmozjs.so => /opt/hfs9.5.220/mozilla/libmozjs.so (0x00007fbc7e6cc000)
libxpcom.so => /opt/hfs9.5.220/mozilla/libxpcom.so (0x00007fbc7e46e000)
libplds4.so => /opt/hfs9.5.220/mozilla/libplds4.so (0x00007fbc7e36b000)
libplc4.so => /opt/hfs9.5.220/mozilla/libplc4.so (0x00007fbc7e266000)
libnspr4.so => /opt/hfs9.5.220/mozilla/libnspr4.so (0x00007fbc7e11d000)
libz.so.1 => /opt/hfs9.5.220/dsolib/libz.so.1 (0x00007fbc7e007000)
libHoudiniUT.so => /opt/hfs9.5.220/dsolib/libHoudiniUT.so (0x00007fbc7d532000)
libpython2.5.so.1.0 => /usr/lib/libpython2.5.so.1.0 (0x00007fbc7d1c2000)
libutil.so.1 => /lib/libutil.so.1 (0x00007fbc7cfbf000)
libboost_iostreams-gcc-mt-1_33_1.so.1.33.1 => /opt/hfs9.5.220/dsolib/libboost_iostreams-gcc-mt-1_33_1.so.1.3
3.1 (0x00007fbc7ceb7000)
libxml++-2.6.so.2 => /opt/hfs9.5.220/dsolib/libxml++-2.6.so.2 (0x00007fbc7cd96000)
libxml2.so.2 => /opt/hfs9.5.220/dsolib/libxml2.so.2 (0x00007fbc7cb5e000)
libglibmm-2.4.so.1 => /opt/hfs9.5.220/dsolib/libglibmm-2.4.so.1 (0x00007fbc7ca12000)
libiconv.so.2 => /opt/hfs9.5.220/dsolib/libiconv.so.2 (0x00007fbc7c837000)
libsigc-2.0.so.0 => /opt/hfs9.5.220/dsolib/libsigc-2.0.so.0 (0x00007fbc7c732000)
libpthread.so.0 => /lib/libpthread.so.0 (0x00007fbc7c516000)
libresolv.so.2 => /lib/libresolv.so.2 (0x00007fbc7c300000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007fbc7bff5000)
libm.so.6 => /lib/libm.so.6 (0x00007fbc7bd74000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00007fbc7bb66000)
libc.so.6 => /lib/libc.so.6 (0x00007fbc7b804000)
libXcomposite.so.1 => /usr/lib/libXcomposite.so.1 (0x00007fbc7b602000)
libXdamage.so.1 => /usr/lib/libXdamage.so.1 (0x00007fbc7b400000)
libpangoft2-1.0.so.0 => /usr/lib/libpangoft2-1.0.so.0 (0x00007fbc7b1d4000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x00007fbc7af55000)
libexpat.so.1 => /usr/lib/libexpat.so.1 (0x00007fbc7ad31000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x00007fbc7ab2f000)
libpng12.so.0 => /usr/lib/libpng12.so.0 (0x00007fbc7a90a000)
libpixman-1.so.0 => /usr/lib/libpixman-1.so.0 (0x00007fbc7a6dc000)
libxcb-xlib.so.0 => /usr/lib/libxcb-xlib.so.0 (0x00007fbc7a4db000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x00007fbc7a2c0000)
/lib64/ld-linux-x86-64.so.2 (0x00007fbc8153d000)
librt.so.1 => /lib/librt.so.1 (0x00007fbc7a0b7000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00007fbc79eb2000)
Firefox version:
- rvinluan
- 1296 posts
rhyshawkins
Yeah. This sounds like an installer bug all right. Just curious, what does “ls -lh /usr/lib/libglib*” output for you?
Also, now that you've deleted libg* from $HFS/dsolib, what does the ldd output for hbrowser-bin look like?
Rob
- rhyshawkins
- 4 posts
Hi Rob,
Output below.
Rhys
-rw-r–r– 1 root root 1.4M 2008-08-08 23:43 /usr/lib/libglib-2.0.a
-rw-r–r– 1 root root 823 2008-08-08 23:42 /usr/lib/libglib-2.0.la
lrwxrwxrwx 1 root root 23 2008-09-04 15:05 /usr/lib/libglib-2.0.so -> libglib-2.0.so.0.1600.4
lrwxrwxrwx 1 root root 23 2008-09-04 15:05 /usr/lib/libglib-2.0.so.0 -> libglib-2.0.so.0.1600.4
-rw-r–r– 1 root root 767K 2008-08-08 23:43 /usr/lib/libglib-2.0.so.0.1600.4
lrwxrwxrwx 1 root root 23 2008-08-07 12:16 /usr/lib/libglibmm-2.4.so.1 -> libglibmm-2.4.so.1.0.25
-rw-r–r– 1 root root 354K 2008-07-26 02:24 /usr/lib/libglibmm-2.4.so.1.0.25
lrwxrwxrwx 1 root root 43 2008-08-07 12:16 /usr/lib/libglibmm_generate_extra_defs-2.4.so.1 -> libglibmm_generate_extra_defs-2.4.so.1.0.25
-rw-r–r– 1 root root 23K 2008-07-26 02:24 /usr/lib/libglibmm_generate_extra_defs-2.4.so.1.0.25
> echo $LD_LIBRARY_PATH
> ldd ./hbrowser-bin
linux-vdso.so.1 => (0x00007fffd55fe000)
libgtk-x11-2.0.so.0 => /usr/lib/libgtk-x11-2.0.so.0 (0x00007f39ccc4c000)
libgdk-x11-2.0.so.0 => /usr/lib/libgdk-x11-2.0.so.0 (0x00007f39cc9b2000)
libatk-1.0.so.0 => /usr/lib/libatk-1.0.so.0 (0x00007f39cc792000)
libgdk_pixbuf-2.0.so.0 => /usr/lib/libgdk_pixbuf-2.0.so.0 (0x00007f39cc578000)
libpangocairo-1.0.so.0 => /usr/lib/libpangocairo-1.0.so.0 (0x00007f39cc36d000)
libfontconfig.so.1 => /usr/lib/libfontconfig.so.1 (0x00007f39cc13c000)
libXext.so.6 => /usr/lib/libXext.so.6 (0x00007f39cbf2b000)
libXrender.so.1 => /usr/lib/libXrender.so.1 (0x00007f39cbd22000)
libXinerama.so.1 => /usr/lib/libXinerama.so.1 (0x00007f39cbb20000)
libXi.so.6 => /usr/lib/libXi.so.6 (0x00007f39cb917000)
libXrandr.so.2 => /usr/lib/libXrandr.so.2 (0x00007f39cb710000)
libXcursor.so.1 => /usr/lib/libXcursor.so.1 (0x00007f39cb506000)
libXfixes.so.3 => /usr/lib/libXfixes.so.3 (0x00007f39cb301000)
libpango-1.0.so.0 => /usr/lib/libpango-1.0.so.0 (0x00007f39cb0bd000)
libcairo.so.2 => /usr/lib/libcairo.so.2 (0x00007f39cae52000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x00007f39cab4f000)
libgobject-2.0.so.0 => /usr/lib/libgobject-2.0.so.0 (0x00007f39ca90a000)
libgmodule-2.0.so.0 => /usr/lib/libgmodule-2.0.so.0 (0x00007f39ca707000)
libdl.so.2 => /lib/libdl.so.2 (0x00007f39ca503000)
libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0 (0x00007f39ca243000)
libgtkembedmoz.so => /opt/hfs9.5.220/mozilla/libgtkembedmoz.so (0x00007f39cd2d6000)
libmozjs.so => /opt/hfs9.5.220/mozilla/libmozjs.so (0x00007f39ca078000)
libxpcom.so => /opt/hfs9.5.220/mozilla/libxpcom.so (0x00007f39c9e1a000)
libplds4.so => /opt/hfs9.5.220/mozilla/libplds4.so (0x00007f39c9d17000)
libplc4.so => /opt/hfs9.5.220/mozilla/libplc4.so (0x00007f39c9c12000)
libnspr4.so => /opt/hfs9.5.220/mozilla/libnspr4.so (0x00007f39c9ac9000)
libz.so.1 => /opt/hfs9.5.220/dsolib/libz.so.1 (0x00007f39c99b3000)
libHoudiniUT.so => /opt/hfs9.5.220/dsolib/libHoudiniUT.so (0x00007f39c8ede000)
libpython2.5.so.1.0 => /usr/lib/libpython2.5.so.1.0 (0x00007f39c8b6e000)
libutil.so.1 => /lib/libutil.so.1 (0x00007f39c896b000)
libboost_iostreams-gcc-mt-1_33_1.so.1.33.1 => /opt/hfs9.5.220/dsolib/libboost_iostreams-gcc-mt-1_33_1.so.1.33.1 (0x00007f39c8863000)
libxml++-2.6.so.2 => /opt/hfs9.5.220/dsolib/libxml++-2.6.so.2 (0x00007f39c8742000)
libxml2.so.2 => /opt/hfs9.5.220/dsolib/libxml2.so.2 (0x00007f39c850a000)
libglibmm-2.4.so.1 => /usr/lib/libglibmm-2.4.so.1 (0x00007f39c82b2000)
libiconv.so.2 => /opt/hfs9.5.220/dsolib/libiconv.so.2 (0x00007f39c80d7000)
libsigc-2.0.so.0 => /opt/hfs9.5.220/dsolib/libsigc-2.0.so.0 (0x00007f39c7fd2000)
libpthread.so.0 => /lib/libpthread.so.0 (0x00007f39c7db6000)
libresolv.so.2 => /lib/libresolv.so.2 (0x00007f39c7ba0000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007f39c7895000)
libm.so.6 => /lib/libm.so.6 (0x00007f39c7614000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00007f39c7406000)
libc.so.6 => /lib/libc.so.6 (0x00007f39c70a4000)
libXcomposite.so.1 => /usr/lib/libXcomposite.so.1 (0x00007f39c6ea2000)
libXdamage.so.1 => /usr/lib/libXdamage.so.1 (0x00007f39c6ca0000)
libpangoft2-1.0.so.0 => /usr/lib/libpangoft2-1.0.so.0 (0x00007f39c6a74000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x00007f39c67f5000)
libexpat.so.1 => /usr/lib/libexpat.so.1 (0x00007f39c65d1000)
libXau.so.6 => /usr/lib/libXau.so.6 (0x00007f39c63cf000)
libpng12.so.0 => /usr/lib/libpng12.so.0 (0x00007f39c61aa000)
libpixman-1.so.0 => /usr/lib/libpixman-1.so.0 (0x00007f39c5f7c000)
libxcb-xlib.so.0 => /usr/lib/libxcb-xlib.so.0 (0x00007f39c5d7b000)
libxcb.so.1 => /usr/lib/libxcb.so.1 (0x00007f39c5b60000)
libselinux.so.1 => /lib/libselinux.so.1 (0x00007f39c5944000)
/lib64/ld-linux-x86-64.so.2 (0x00007f39cd21b000)
libpcre.so.3 => /usr/lib/libpcre.so.3 (0x00007f39c571e000)
librt.so.1 => /lib/librt.so.1 (0x00007f39c5515000)
libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00007f39c5310000)
Output below.
Rhys
opt/hfs9.5.220/dsolib> ldd ./hbrowser-bin
- rvinluan
- 1296 posts
rhyshawkins
Hi Rob,
Output below.
Rhys
Thanks for the output Rhys. It definitely looks like a problem with the installer. I'll check it out when I get a chance.
Rob
- rhyshawkins
- 4 posts
