PBR rendering of volumes
14439 16 1-
- koen
- 795 posts
- jason_iversen
- 12999 posts
If you use the VEX Volume Cloud shader, it has support for isotropic() VEX function which supports isotropic scattering of light within a volume.
Don't use the material in the Material Palette; they haven't added isotropic() to it (yet).
Post some results
Jason
Post some results
Jason
- koen
- 795 posts
- JasonSlab
- 1535 posts
o cool, does this mean we will be getting some pbr SSS shaders soon?
jason
jason
fx and lighting @ rebelway
https://www.youtube.com/@jason_slab
- koen
- 795 posts
Hello Jason,
You seem to be very well skilled in uncovering semi hidden and undocumented features :-). I have found the call to isotropic in the code for the vex volume cloud. I could not find documentation on this function. In the vex volume, it takes no arguments, that would probably mean it gets info from the volume.
I would guess that the absorbtion is simply related to the density. If I would like to add scattering, how would I define the scattering coefficient?
Thanks,
Koen
Thanks,
Koen
- jason_iversen
- 12999 posts
koen
Hello Jason,
Years of scouring the development Journals has made me a great scavenger, a sort of Fisher King
koen
AFAIK, the scattering coefficient is directly related to the density of the Volume, you're right. The big difference with rendering Volumes with scattering is that now the scattering works across a heterogeneous medium as opposed to a homogeneous medium (varying vs. constant density). What you're probably lacking is a control to cheat that apparent density, yes? I wonder if the light's Shadow Density can provide that control? Another control to boost the scattering contribution, perhaps?
- koen
- 795 posts
Hey Jason,
In a heterogeneous medium, I would like to control three phenomena,
Absorption, Emission and Scattering.
The combined effect of Absorption and out-scattering seems to be controlled by the density, eg. how much light continues on the current path.
I am not quit sure how to account for the in-scattering, the lighting up of surrounding volume because of the light scatterd. To use this I would have to split the attenuation in its constituent parts. Currently however, I am interested most in controlling the emission (because I am looking at explosions) Is there a field in the volume I can set to control how much energy is added to the system by a voxel?
Thanks for your help!
Koen
Koen
- jason_iversen
- 12999 posts
Hi again,
It would seem that a factor on the isotropic() component would give you some control over the apparent absorption and out-scattering, wouldn't it? Although I think would still be nice to somehow cheat/replace the density of the medium - it's scary to think how easy it would be to add far more light to the volume than what originally entered it and getting into a glowing mess.
As for “how much light continues on the current path”, I might be on the wrong path here, but are you talking about introducing a phase, to emulate single scattering? (sorry, the terms in-scattering is a little vague to me). I suppose this would not longer be called isotropic scattering then.
As for emission, this should be be able to be handled by just adding in some colour, no? As you would with a hard surface where you can just set a constant colour and it would provide illumination by indirect diffuse reflection. Using photons would be a lot more efficient (hopefully), but I'm not even sure photons are aware of volumes yet.
This warrants a few tests
At least while we wait for SESI to set us on the straight and narrow..
koen
koen
- koen
- 795 posts
True, time to just run some tests.
With in-scattering I mean the incoming scattering from neighboring volume, so the “out scatter” of one place is the“in-scatter” for another. But I have to admit I am no expert, I'll have to read up a little. But I definitely want to keep it iso-tropic, I'm having a hard enough time already on simple surfaces with an-isotropic behaviour :-)
I had not thought of just piping in color values over 1, again, let the trials begin :-)
Thanks again,
Koen
Thanks again,
Koen
- jason_iversen
- 12999 posts
You know, I've just been playing with this and I'm getting very odd results with 9.5.225 that make me think that PBR Volumes are broken. They only seem to accept illumination from one light source - and to boot I'm seeing no scattering. I'm going to update to the latest and try again.
Aw, I've reached my maximum upload quota of 20mb or I'd post images. :cry:
- jason_iversen
- 12999 posts
9.5.248's results are the same, I'm afraid. Have you have any more luck?
I'm not sure what's going on :-/
- koen
- 795 posts
- andrewc
- 1002 posts
Some limited rendering of volumes in PBR is available in 9.5. The limitations are:
- No support in gallery material shaders
- No emissive volume support
- No photon support
- Only isotropic scattering
Attached is an example using 2 lights. This uses the VEX volume cloud shader, which is set up to correctly render volumes with PBR. PBR uses opacity in a similar way to micropolygon rendering, but you should *not* premultiply the bsdf by the opacity before exporting it (see the VEX volume cloud shader for how to do this in VEX.)
- No photon support
- jason_iversen
- 12999 posts
Thanks Andrew,
I was wondering if you could clear something else up for me?
I've sent a narrow beam of light through the Volume and I notice two things:
*) If I turn up the intensity of the beam (from 1 to 50), I don't see any deeper scattering of light into the Volume. I'd expect to see the beam bleed into the Volume further. Am I wrong in my expectations?
*) BUG: In the attached file, if I set the /obj/spotlight1 cone down to 10 degrees, the beam totally vanishes. I can get it to re-appear if I turn off the other lights in the scene, but there is definitely something awry.
Gah! Still can't attach stuff. I'll probably have to post elsewhere..
- koen
- 795 posts
- andrewc
- 1002 posts
jason_iversen
Thanks Andrew,
Increasing the intensity of the light will just increase the brightness of the illuminated parts of the volume - it won't cause any additional scattering. If you want extra diffuse bounces, it's necessary to increase the “diffuse limit” on the mantra ROP (PBR tab). However, isotropic scattering does not lead to very interesting multi-scattering effects.
jason_iversen
Please submit a bug for this.
Andrew
- jason_iversen
- 12999 posts
andrewc
Ah, I assumed that your scattering was the Jensen-style exponential extinction, which (if I understand it correctly) should allow the light to be visible deeper into the medium. However, I'm picking up that you're using a different model - or have a cutoff distance, perhaps?
jason_iversen
Submitted.
