Hello everybody,
I just played around with the flipbook and wanted to change the output to save directly to the disk, but no matter what I enter into the Output field, I always get “Image file save error: Unable to create image XXX.XX”
I tried different formats, different paths, with and without extension and with or without $F for the frame number. The only thing that works is ‘ip’, i.e. MPlay.
Is there any special format that I have to use for the filename?
Flipbook generates "image file save error"
8823 6 2-
- EvilMinion
- 9 posts
- edward
- 8083 posts
- EvilMinion
- 9 posts
- circusmonkey
- 2624 posts
Try this ie ,
your HIP
G
Projects_vfx_houdini/project/hip/rse_particleFluidTest01.hip
Your renders
G
Projects_vfx_houdini/project/images/rse_particleFluidTest01.$F4.tif
so in your render path you would type
$HIP/../../images/rse_particleFluidTest01.$F4.tif
/../../ denotes go up one level then down , hope this helps. Also you really should upgrade that version to a new shiny one !
Rob
your HIP
G
Projects_vfx_houdini/project/hip/rse_particleFluidTest01.hipYour renders
G
Projects_vfx_houdini/project/images/rse_particleFluidTest01.$F4.tifso in your render path you would type
Rob
Gone fishing
- EvilMinion
- 9 posts
- edward
- 8083 posts
- Sadjad Rabiee
- 1391 posts
EvilMinion
Still doesn't work, but I'll update my version now. Thanks for mentioning that! I thought the apprentice version would be updated in larger intervals and you could only get the newest build with the commercial version.
Yes ,edward right ,I have no problem with Apprentice version too,Can Can you upload a simple file about your problem for us !? :?
Also check your access permissions ,Maybe it's because that !
