Hello
Simple question: If I have an object with a textured surface and reflections, how do I render a separate pass for only the reflections without the textures? Thanks!
phoenix1606
rendering reflection map
4439 3 1-
- phoenix1606
- 18 posts
- stevenong
- 1634 posts
Hi there,
You can first render the Object with only texture maps applied but without reflections. Next, you'll remove the texture maps and set the reflection values to 1,1,1.
Once done, you can go to COPs and use a Composite COP to add two images together though you will probably want to use a Brightness COP to adjust the intensity of the reflections.
I hope I have not misunderstood what you're asking for.
Cheers!
steven
Cheers!
steven
- phoenix1606
- 18 posts
Hi
Thanks for the help! Only problem is that I created my own shader in VOPs where I attached a Wood Plank VOP to the color input of the Output VOP. The Wood Plank VOP has reflections integrated into it, so I don't know how to turn off the texture while maintaining the reflections. Please advise. Thanks!
phoenix1606
phoenix1606
- stevenong
- 1634 posts
