How to switch off the default light ?
   17140   6   1
Sorry for this silly question, but how to switch off the default light ?
I tried to search in the help, but the help system is so bad… :-(
Thanks.
Put a light in the scene.
“everything is coincident”
probbins
Thanks, but it doesn't work with an environment light.
I can still see some speculars.
Note that there's a display option in the viewer to turn off specifically, specular.
Yes, I knew, but it was to insist on the fact that the default light was still there. :-)
That's because the environment light does not count as an OpenGL light in the viewport by default. You can change this with the “Enable Light In Viewport” toggle on the light itself, but an environment light without translates will often end up inside geometry.
OK, thank you !
