How to render massive 3.5 simulation rib with Prman
   6913   1   1
Hi everybody
I'm using massive 3.5 with Prman 13.5
step 1 :I load massive rib in Geometry Node Geometry As “Render from file” and rib path
step 2 :H8 renderman node the procedural path set to the location of Massive
Final i got Massive Geometry rendered in houdini without texture.
In massive i used paintedplastic with texture files are *.tex format.
it's texture or shader problem?
how to get textures also in houdini rendering
what are more step i want to follow
Is it the master.rib or the archive.rib that you load?
Is the procedural path the installation root of Massive?
thanks,
bern
