hi
I'm trying to setup a interior PBR scene, as soon as i use Physically Correct Attenuation on my lights the scene becomes to noisy to even see whats going on.
so the question is, are we NOT supposed to use physically correct lights for physically based rendering? :?
jason
PBR lights:Physically Correct Attenuation
7533 3 0-
- JasonSlab
- 1535 posts
- probbins
- 1145 posts
- eetu
- 607 posts
Ok, this is just a gut feeling, but you might want to check if you have a light source very close to a surface, making a very bright spot.
Realistic falloff means 1 / (distance^2), and, depending on how it's implemented in render engines, that means that it might approach infinity when distance to light approaches zero. If one sampling ray of a given pixel hits a very very bright spot created this way, it can overwhelm all the other samples and produce really nasty noise.
.. or of course it could also be something very different, my gut is a fickle thing
eetu.
eetu.
- JasonSlab
- 1535 posts
hi
thx for the reply's
ok so I'm doing some tests on this.
what I'm noticing is a huge increase in noise when i add a fill(point light) or environment light to the scene, there is still alot of noise at 30x30 samples.
take note of the render times/noise/samples on the Half Attenuation render vs the Physically Correct one
another thing, is the grid area light supposed to create a circular hotspot?
[divshare.com]
[divshare.com]
[divshare.com]
[divshare.com]
[divshare.com]
jason
thx for the reply's
jason
fx and lighting @ rebelway
https://www.youtube.com/@jason_slab
