Iso offset node showing issues on more dense voxel grids
5090 4 1-
- koen
- 795 posts
hello all,
While converting meshes to a smoke volume, I often found the same problem appearing once I started to crank up the grid resolution. There are “lines” leaking from the surface. I assume it has to do with the ray intersect algorithm, but I did not get better results using different algorithms.
Are there any know tricks to solve this?
Koen
Koen
- koen
- 795 posts
- eetu
- 607 posts
- koen
- 795 posts
- koen
- 795 posts
