Ship Kelvin Wake
   11119   4   1
Now it can be done in houdini, i am very poor with vex and vop.
Maybe some idea…
Thanks in advance
Ship Kelvin Wake
http://www.wikiwaves.org/index.php/Ship_Kelvin_Wake [wikiwaves.org]
WEB
http://www.igorfx.com/ [igorfx.com]
Vimeo
https://vimeo.com/igorzanic [vimeo.com]
One way to do it would be using a simple particle simulation.
I've attached a hip file that shows this method and uses the particles to displace the ocean surface geometry.
You could also use a greyscale render of the particles as a displacement shader.
boatWakeExample.hip (138.0 KB)
have you tried the ripple solver in DOPS? might be a good place to get a general motion going
jason
fx and lighting @ rebelway
https://www.youtube.com/@jason_slab
chopstix thanks for example… I will try
jason|slab i try rippleDop solver, and it has nice resault, i just cheking for some other solution
WEB
Vimeo
No problem.
Another thing to note in my example setup is I hard coded the initial velocity so it only works on the X axis.
You can improve the setup by using the ship hulls normals as velocity (just put $NX,$NY,$NZ into velocity in a point sop after you've transfered the N att to the emission curves) This way the wake motion will continue to spread out behind the boat regardless of which direction it is traveling.
