when i press the render button, and i got a warning signal.
S01001 {WARNING} Cannot load shader “first”. (System Error: No such file or directory)
why? :cry:
i got a problem with my custom shader in houdini~(randerman)
4297 3 0-
- VFXCSN0309
- 14 posts
- Pagefan
- 519 posts
Well obvious prman can't find the shader. So you could check if you do have a shader called first in your houdini scene and if so, you could check the rib file to see if it references the right path. You can create a rib by using a RIB archive rendernode iirc.
Here is a link for all the renderman error messages
http://staffwww.itn.liu.se/~stegu/TNM022-2006/Pixar_RPS_13.0_docs/reference/messages/xcpt.html [staffwww.itn.liu.se]
Hope this helps
Hans
Hope this helps
Hans
- ykcosmo
- 288 posts
- VFXCSN0309
- 14 posts
