I have been recently trying to do some work using the split-view setup. Everything looks good, except I can't figure a way to quickly select a viewport I want to work with. I found two ways to select the viewport: (a) by using the display context menu, and (b) by using the “n” shortcut key, which would be fine, if it weren't necessary to position the mouse in a very small area, where the context is right and the key works.
Is there a way to force the viewport-select shortcut key to work all over each viewport area, rather than just over the display & cam menus?
And, is there a config option to activate each view in the split-view layout automatically, upon clicking/performing any action with the mouse in a given viewport? This is the behavior typical to other 3D apps, so I'd assume that SideFX must have had a good reason to decide for a more explicit viewport selection - I wonder why this way?
Thanks,
Greg
Quickly selecting viewport in split-view - how?
7189 5 1-
- aiworks
- 130 posts
- jason_iversen
- 13095 posts
In the past, it was space+x over the split viewport to select one to be made active.
- aiworks
- 130 posts
- Ondrej
- 1082 posts
- rafal
- 1471 posts
- aiworks
- 130 posts
