hi!
If i add a parameter node to export refraction, for using as image plane, the render slows down drastically.
If i delete the image plane, and the parameter node, it stays slow as hell.
If i put down a new glass shader it is much faster again.
Anyone bumped into this or has an idea what could this be?
Glass shader problem
7025 4 0-
- buki
- 1773 posts
- JColdrick
- 4140 posts
Yeah, on linux I can repro this for a trivial example, I get render times of:
Render Time: 33.72u 0.38s 11.08r
before adding the refract layer. When I add it, it goes up to:
Render Time: 1:09.40u 0.52s 21.01r
after adding and stays that way after deleting the export and the extra layer on the ROP. Note that a restart ‘fixes’ it - it is arguably a bug, although I would be interested in the results of a non-trivial test. We output extra layers all the time and certainly haven't noticed a sudden huge hit on render times when adding them. This might be a ‘one time’ hit when exporting something other than RGBA, and the fact it hangs around for the rest of that session is either a quirk or a bug(even possibly by design for a reason we don't know).
J.C.
J.C.
John Coldrick
- buki
- 1773 posts
I hope someone from SESI will inspect this, anyway thanks for taking the time looking into the problem.
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
- madjestic
- 326 posts
- buki
- 1773 posts
reported.
