Dragon
   10523   2   0
Hi every body, recently I started the head of this dragon
[img3.imageshack.us]
but i have had problem with the horn in the crest
[img39.imageshack.us]
i would like a tip for this
thank you
It seems reasonably straightforward. Use the Polyextrude to scale down and then inset an extrusion or two, then scale down and pull up the horn. I've attached a simple example.
Keep the Polyextrudes set to “local control” and you can do both main horns simultaneously.
Generally I would suggest you are adding too much detail too early with your head. You'll be adding in specific details later with polysplit and edgeloops, so keep the head much simpler at this stage.
horn_inset.hip (55.7 KB)
“everything is coincident”
thnak you, but i have problem with download the file, the topic dont display very well, it cut i think is for the size of my pics
