I'm beginner and I work through Buzz Basic Network
And I get seriusly counfused.
Okay,I ‘ll describe.
I go in SOP,Network editor and create grid in the middle of the screen; TAB-grid
Than,I get that move handle
I move grid to the right of screen
and I see a little x,y,z handles where grid was originaly created
and I create from grid another node-Transform
and now when I want to rotate,scale,translate,I get that handles not at the center of my grid bit where it was originaly created
It’s center is offseted from object-OR vice verse
it seems that center of object transform handles is detached from my object center from the moment of the sreation
So I need ro align thoise two again exactly
But how?
Object's transform handle offset from my object's center
4857 1 2-
- Ben Lumumba
- 58 posts
- tallkien
- 225 posts
When you move the grid initially, if you look in the parameters page you'll see that you've modified the grid's “center” field. Just reset those back to 0 0 0 and use the transform to move the grid.
Alternatively, you can leave the grids center as it is and type $CEX $CEY $CEZ in the transform sops pivot filelds to snap the center back to the center (centroid) of the Grid.
I prefer the first coz it keeps things generally tidy
cheers
tallkien
cheers
tallkien
