problem running houdini apprentice on ubuntu 32bit
   5958   5   1
Hey,
first post to this board
Well, I'm not able to get houdini to run on my ubuntu 9.04 32 bit system. Installation works fine until I type “houdini” to launch the app. Then it says “cannot execute binary”. I assume this is a 32bit/64bit issue?
At the download-page for the apprentice there's no way to say whether you want it for 32 or 64 bit. Should that file work on both? I'm a bit suspicious since it says “64” somewhere in the filename of the file I downloaded…
I hope there's someone who's had the same problem and solved it somehow
Greetz,
mg.
edit: yes, I spent some time searching this board but I didn't find a solution. If there is, point me to the thread please
You need the download titled Ubuntu 7.04 gcc4.1 with “i686” in the filename.
Here is a direct link. http://www.sidefx.com/index.php?option=com_download&Itemid=208&page=license&version=10.0&build=424&platform=linux_i686_gcc4.1&format=tar.gz [sidefx.com]
Side Effects doesn't build a 32 bit package for ubuntu 9.04, so this is the next usable package.
www.alan-warren.com
thx, alan. that did the trick.
I've been able to start houdini now, got some errors and followed the instruction to delete the libs in install-dir/hsvg/. Now I can see the UI but when clicking buttons it takes a long time until houdini reacts… any ideas?
though I can see Houdini finally, the console gets a flood of errors. last one is this:
X11 Error(9): BadDrawable ( invalid Pixmap or Window parameter )
One user posted his solution was to update his ATI driver. I use a NVIDIA card, so this might not be the solution for me Is there a rule of thumb which driver-version works best with houdini? I'm using a Geforce 9600M GT.
Have you installed a proprietary Nvidia driver, or do you have whatever comes with Ubuntu by default? Check if you have direct rendering capability.
glxinfo | grep direct
Otherwise I'm not really sure since I haven't used Ubuntu since 7.10.
www.alan-warren.com
I have to admit that I don't have a proprietary nvidia driver. I'll try that when I come home tonight…
Thanks again for your help!
hey alan,
i just checked and I have direct rendering enabled. Next think I did was to install the latest nvidia driver and houdini runs *much smoother now. Not perfect yet but I'll have a look at older drivers and such. Thx, bro
