Mac dmg frustration
   10136   5   0
I've just been trying to get Houdini installed again on my macbook but I have tried downloading
10.0.401, 430 and 450
they all give me a “the following disk failed to mount - not recognized” error. I find it hard to believe that there's anything wrong with the DMG from sideFX because someone would have mentioned it by now, so is there some magic I need to get it to work…?
cheers
John
john @ goodbyekansas
Is your mac 64bit?
Hi, I should have said
OSX 10.5.8 Leopard so yes, 64bit I have had apprentice running on this machine before but I uninstalled it but now I can't open any of the DMGs that I have downloaded from sideFX
Cheers
John
That's strange. I'd check the MD5 sum values and make sure they match.
Hello there, at some point in time, one of the leopard releases, made MANY .dmg files seem to be “unusable” to open, but all you need to do, *i hope in your case really*, is instead of “double clicking” the .dmg, you should just RIGHT CLICK THE .dmg, then go to “more” and “mount it”…
Hope that works for you!
Jonathan
itriix
Jonathan
Thanks for all the replies. I downloaded again, this time using Safari. I don't know if it was that or something else but it's working now on the 430 release. Yay!
Cheers
John
