viewing UV Texture Image in Houdini imported from photoshop
   12893   15   1
Hi :
I ‘ve painted a UV texture image ( of a grid) in photoshop and exported to houdini’s shop level. I did assign it on color map and on OGL texture layer.
But i still can not view them in the view port without actually rendering them.
How can i view the texture color image in the view port without rendering them.? I can view through render region though. Thank you very much in advance.
Steve
What you describe sounds like it should work except that you don't mention which SHOP (shader op) node you are using. I just tried a default General > Decal from the Material pane and it worked for me. Maybe you have texture display turned off in the display option off?
Try something basic first:
- Create a default Grid from the shelf
- Select all the primitives at the geometry level
- Click on UVQuickShade from the Texture shelf
edward
Thank you very much for responding to my question.
I used “ basic surface ” from general.
Where is the texture display in display option ?
I can't find such an option. Can you further help me ?
Thank you very much again.
Steve
Basic Surface worked for me too (see attached). As for the display option, hit ‘d’ with your mouse in the viewer. Look in Misc > Display Textures.
texture.hipnc (172.7 KB)
When you assign the Basic Surface, with the texture in it, does the geometry turn a dark pink? If so, then the material is working, the colour usually means the path to the texture image is wrong.
Create a new pane tab and launch a Shader viewer and see if the texture image shows there.
“everything is coincident”
edward
I appreciate your help.
Yes, It's checked already.
Should i check on projected texture and Shadows ?
Steve
Edited by - Nov. 17, 2009 13:28:28
probbins
Thank you very much.
I will check it out.
Steve
probbins
Yes, I can see all the texture in the shader view.
Those are for a 3 D model and grid for the flaggs i made in houdini.
Yes, geometry turns to pink. Actually, i painted solid pink color for the geo.
I noticed that plain and solid colored layer for the 3D model in the photoshop can be seen OK in houdini viewer.
But, the color i painted on the UV texture of a grid can not bee seen in the houdini viewer.
Would you please further help me ?
Steve
Edited by - Nov. 17, 2009 13:31:33
probbins
Yes, It turns to dark pink.
edward
I did it. Looks everything is OK.
What should i do next ? Tks
Steve
aplink
edward
So you're saying the with the basic setup shows the texture map in your viewport right?
You've tried the display options and “Texture Display” is enabled?
If your answer is yes to both of these questions, then try posting your .hipnc file.
edward
aplink
edward
Here is the hip file for your review.
And, how can i get rid of the rows and columes of the flags when i view the texture in the scene view.
I do not have any problem with other flags and stick to view the texture.
except the rows and columes in the other flag.
Steve
TEXTURE_Test.hipnc (344.7 KB)
On your Skin SOP, change the Connectivity to Quadrilaterals. When you have it as Rows & Columns, there is no surface to texture, only wireframe.
edward
But, I only can view texture on only one side of the flag with Quadrilaters using smooth shaded and smooth wire shaded.
Wonder why ? May be because i painted only one side of UV in photoshop ? ? ?Would you please help me further.
Thank you so much.
Steve
Sorry, I don't understand your question. Both sides are show the (same) texture map for me.
edward
When i flap(rotate) the flags (grid object) i only can see the texture (color) of one side not both side. I wonder why ?
Steve
