got stuck again…
I have a polygon with an attribute that specifies a thickness. I would like to use the Wireframe or Polywire SOP to thicken my line, and I would like to set the radius according to my attribute.
I tried writing an expression in the Radius parameter box, like this
prim = hou.pwd().curPrim()
return prim.attribValue(“thickness”)
but that throws an error… the error message says: “ Not currently iterating over primitives”
Any suggestions…
iterating over prims
3937 2 0-
- phtj
- 224 posts
- phtj
- 224 posts
- graham
- 1928 posts
The error message is a result of the fact that the PolyWire Sop doesn't perform its operation on a primitive by primitive basis (it doesn't iterate over each primitive and operate on it individually like you want it), hence the error message about it not iterating over primitives. Using the ForEach is probably your best bet.
