Flip Normals
   57812   6   2
Hi i am wondering if anyone can tell me how to flip a single primitive, so that its normal is facing the other way ? As i have created a model and all the normals are facing in the oposit direction.
Look at the primitive sop->face/hull tab->vertex->reverse.
G
Or just use the Reverse SOP.
Cheers
Well. How would you do this, if you have a very complex model, too tedious to select each flipped manually. And you want to select all visible backfaces?
fake_pilot
I'd use a prim wrangle to do a neighbours lookup. If the dot product of the current prim normal and the avg neighbours normal is too different (let's say, dot < 0), then flip the face. It might need multiple iterations to reverse all backfaces of the model.
This, or try the Polydoctor first. This SOP can repair all kinds of issues.
