I was wondering if anyone could suggest an efficient way to create a hovering “dry ice” type of fog effect in Houdini. Here's an example of what I'd like to achieve:
http://www.youtube.com/watch?v=hsLoI_17ncU&NR=1 [youtube.com]
I'm assuming that this could be done using a volumetric smoke container but I'm wondering what the trick is to keeping the fog from dispersing while still having a fluid motion.
I was also messing with the sprite fog shader using particles but I couldn't figure out the proper way to use it.
Thanks for your help!
Nick
Dry Ice simulation?
16774 7 3-
- ultraharmonizer
- 63 posts
- ultraharmonizer
- 63 posts
- circusmonkey
- 2624 posts
- ultraharmonizer
- 63 posts
Rob,
How would you recommend adding the noise? I've tried adding noise to the geo using a moutain sop (creating an ocean type of noise effect) and it seems to be working but should I be adding it somewhere within my dop network or to the material somehow… any suggestions?
Also, how does one keep from having the volume disperse? I made the bounding smoke box smaller and it seems to be holding it together. Is this how you would recommend doing it?
lastly, what is the recommended way of controlling the opacity of a simulation like this?
I've attached an example of where I'm at…
- circusmonkey
- 2624 posts
- ZeroTucker
- 1 posts
According to a dry ice [http] website, dry ice fog can be created easily. All it takes is water and dry ice. The dry ice fog will last for a while (until it has warmed up). Because the composition of the dry ice fog is heavier than water, it will stay low to the ground. This gives a great effect.
- Tucker
- Soothsayer
- 875 posts
- old_school
- 2540 posts
Here's my quick attempt.
I built a Volume VOP to add noise to the smoke emitter SOP network added by the shelf when I used the Smoke From Object tool.
Cranked up the source volume resolution to 100 in the max dimension in the smoke emitter SOP network.
Removed all boyancy and diffusion hammered to 1.
Added vorticles from the shelf and a bit of vortex confinemet to get some swirls.
