No module named PyQt4
   10955   5   3
Hi!
I'm trying to write something in PyQt4 in Houdini:
I have made new tool and (according to houdini help) I've put there simple script. (the beginning is important
from PyQt4 import QtCore
from PyQt4 import QtGui
And I'm getting error after pressing the new tool:
“No module named PyQt4”
I Have got PyQt4 installed on my Fedora 12 (and I testet it - I've made small application and can run it)
How make it working?
thank you
danilo2
Hi!
thank you
What version of Python is PyQt for? Your Fedora runs defaulty on 2.6 I suppose. My guess is that Houdini chooses 2.5, which is also present on your systems. You need PyQt for a second one so Houdini can find and use it.
Currently Fedora 12 has got python 2.6 only, but I'm trying tofigure how to install 2.5 too
danilo2
In that case I think Houdini uses its own Python. Dirty hack to let it know about your modules is to put it into your $HOME/houdinix.x/scripts/python directory. Assuming it's complied for python 2.5 though…
Ok I've copied PyQt4 there and It is not working - I'm getting error:
“/opt/hfs10.0.545/houdini/scripts/python/PyQt4/QtCore.xo: undefined symbol: PyByteArray_Type”
So this Qt is not compatible with python 2.5 I think
Has somebody maybe PyQt4 module compiled for python 2.5? or does somebody know where to download it?
danilo2
did you solved that problem?
