How do I split am object for reforming
   7775   1   1
I am woundering how I would split a solid object into two parts so that each is a compleat object. Then be able to fit the peices back to geather with only a seam showing.
first I delete the lower half then move back up the tree and spawn a second delete that removes the opposite half.
when they are merged the original object is restored.
What I want to know is.
How do I Build a surface across the opening of one half that will match the surface that is built over the opening of the second half?
Long winded I know but I have Tried Polyknit and the surfaces do not match.
Thanks Dragon Ranger
Use the “DivideSOP” with “remove shared edges” on ( rest off ),
the ouput are polys from your “holes” in the geometrie. Choose the right one and delete the rest.
Michael Fuchs -|- Owner Sparkling Design -|- Austria
Sparkling Design [sparkling-design.com]
