I'm trying to iterate on a bunch of points groups (using foreach).
“group2__0 group2__1 group2__2 group2__3 group2__4 group2__5 …”
I can get the list of all my groups with the pointgroupmask expression, but after that I don't know how I can count them or get them separately.
For the moment I'm able to get a string attribut with all my groups names separated by a space… but after that…
I don't necessarly need their names, I can iterate if I know the number of points groups
All the troubles cames from the fact that the foreach loop doesn't work with points groups… So I need to convert all my groups to primitives groups, but the group->edit->point to primitive doesn'at accept the * sign, and doesn't accept the list of strings returned by pointgroupmask…
So I think I need to count them in order to iterate the correct number of group… or iterate on each string returned by pointgroupmask but maybe it's more simple.
I hope you get some idea…
Iterate pointGroup by groupCount or trough list of groupName
4527 5 0-
- dealer2couleurs
- 25 posts
- Anonymous
- 678 posts
- dealer2couleurs
- 25 posts
Thank you Swann_, I get it to work with argc…
Maybe this is not the better way to iterate over point groups, but here is the solution I have for now
FOREACH number
1 -> argc( pointgroupmask(“../group2”, “group2*”))
with pointgroupmask, I get the list of all my groups and with argc, I get the number of groups in the list…
after that, I use
group2`stamp(“../../foreach1”,“FORVALUE”,0)-1` as the group name
to compute only for the specified group. The “-1” is used because my groups numbers started at 0.
I hope it can help peoples,
FOREACH number
after that, I use
- mzigaib
- 1021 posts
I need a little help with this maybe you can give me.
I want to iterate just like that but instead of return the group numbering, I want to accumulate a value for each group on a attribute, like:
I have 5 groups so I would have an attribute lets say “grpnumber” accumulating a value of 1 for each group so the result would be “grpnumber = 1”, “grpnumber = 2” until “grpnumber=5”.
One problem is that my groups are not numbered they have different string names and I cant use foreach number because I have too many primitives lets say more than 2K.
I hope I could be clear.
Can you help me to do that?
- Pagefan
- 519 posts
- mzigaib
- 1021 posts
Thanks you for the reply.
Sorry that I couldn't explain my question right.
I´ll try to resume better.
For example, I have 3 primitive groups:
group “wheel”
group “tire”
group “steer”
I also have a primitive attribute, lets say “accum”, that I want to accumulate a value of 1 for each group in a iteration of 3, so I would have something like that:
group “wheel” - accum == 1
group “tire” - accum == 2
group “steer” - accum ==3
I hope I could explain better this time
I´ll try to use the expression, but I don´t know exactly to use it to get what I want.
Thanks anyway.
group “wheel”
group “tire”
group “steer”
Thanks anyway.
