generate prman ObjectInstance
   5131   7   1
Hi!
I want generate object instances for rendering in prman.
If adding Instance properties to points it generate rib like
ArchiveBegin “/obj/teapotobj/points:0”
…..Instance geometry…
ArchiveEnd
ReadArchive “/obj/teapotobj/points:0”
but needed
ObjectBegin 101
….Instance geometry….
ObjectEnd
ObjectInstance 101
I found declaration ObjectInstance in RIBapi, but
not found way how use it. Please help.
novice
Maybe you could write it like this to your own DSO something like this :
pipeline : read the particle info with your DSO -> instance your geo onto the particles
RtString *data;
RtBound bound;
RiProcedural(data, bound, RiProcDynamicLoad, freedata)
You can also have a look at “ cluster this ” plugin for houdini.
Hope this helps.
^_^
^_^
thanx,
I have hoped to avoid write dso, and create this thru standart pipeline.
novice
I seem, you just need to correct soho-side for such behaviour.
demOOn
Hi!
ArchiveEnd
but needed
ObjectBegin 101
ObjectEnd
ObjectInstance 101
You can use the RenderMan Delayed Read Archive SHOP.
1) Put down an instance object.
2) Turn on point instancing
3) Assign the DRA SHOP to the object you are instancing
An alternative to (3) is to put down a material SOP in your instance
object, and set its “Attributes” to “point” (assigning a material per
point), then assign the DRA material onto the points. This would let
you change the DRA on a per-point basis (if you didn't want to
instance teapots at all instances.
Oh, for numeric instance id's, you'll have to turn off the
“stringhandle” feature (see the SOHO python files).
^_^
JoeMislang
I didn't found behaviour for custom properties.
If adding properties ‘ptinstance’ it starting mechanism in RIBgeo.
But inside it using ‘instance’…
I don't understand how it should work.
For example:
I create properties calling ‘rmaninstance’, attaching to points.
How I would read it in RIBgeo? Or not RIBgeo?
novice
:shock:
^_^
