Knots and wires
   5364   2   0
1. Some one have an idea how to approach different knots with wires ?
2. I would also happy to know how to take any given line to move only on course that will determent by curve. ( this will solve some problems in case i will not use real wires with dops)
thanks !
James
Edited by - July 24, 2010 05:02:41
Hi James ,
Sorry but I am a bit baffled as to what you are trying to do. Could you post a basic scene file and give a better explanation. Then it might encourage others help address your problem.
rob
Gone fishing
Thanks , you right .
I`m try to find ways how to generate knots,animated knots.
for future stitching , or just simulation of knots
and
understand better the relations between wires and static\cloth objects.
examples:
http://www.youtube.com/watch?v=v2gxCS5ffWk [youtube.com]
http://www.youtube.com/watch?v=0zW6UIGTzGw&NR=1 [youtube.com]
http://www.youtube.com/watch?v=6a8991PtpaI [youtube.com]
http://www.youtube.com/watch?v=W8_ehaty_bo&feature=related [youtube.com]
so my first questions how to build\animate this knot ( creating_path.hipnc ).
1.there is a way to build line and make it follow the path ?
so the line would move like a snake according to the path?.
2. I look for methods that the wire will able to wrap easily around objects .
Are there any standard nodes available that I could make use of?
3. mahat_hoot.hipnc showing case that my static object not able to affect the wire.
there are mutual forces between wires and static\rbd\cloth objects ?
from my experience here :
wire affect object working fine usually
but does object affect wire ?
static_cloth_tear.hipnc (137.2 KB)
creating_path.hipnc (46.7 KB)
mahat_hoot.hipnc (151.9 KB)
