Hello everyone,
I'm trying to finish up an idea that I had this week. If you look at the image, you may see what my idea is. Each color represents its own group of polis. What I want to happen is that they flip back. Like a bonnet on a car or a hatch, if you will. The two red points indicate the hinge anchors, and the poly group should rotate along the red line.
Here's where I'm stuck though. While it is no problem to move the pivot, I have not found a way to orient it. My idea is to take the two red points and somehow create a local rotation axis out of the vector. I can put the two points in a group, that was not a problem. It's the rotation axis bit I am stuck with. I appreciate your input.
Cheers
Making Hinges / Procedural Pivot Orientation
4763 5 0-
- zarroun
- 23 posts
- agentxray
- 2 posts
- mzigaib
- 1021 posts
- graham
- 1926 posts
I posted a Python SOP implementation in the thread about this on odforce.
http://forums.odforce.net/index.php?/topic/11757-procedural-pivot-orientation/ [forums.odforce.net]
- zarroun
- 23 posts
- zarroun
- 23 posts
All right, I got a decent looking test of what I plan to achieve. There still are some left over polis sticking out, but I'm dealing with those. The idea is to reveal each texture map I've used on this project and then show the final shader. The final will have to be a bit faster than this.
http://www.romanaltenburg.com/temp/transform.mov [romanaltenburg.com]
Cheers
Cheers
