build a line to the nearest point
6512 5 1-
- mickyblue
- 217 posts
- brianBurke
- 192 posts
howdy. point cloud lookups and attribute transfer are both good ways to figure out the nearest neighbor. here's an example that shows both ways.
with attribute transfer: set the kernel radius small, use one sample, and disable distance threshold
with point clouds: set the radius super high and the number of points to one
using either of these methods, you can grab the point number of the nearest neighbor
good luck dude
good luck dude
- tamte
- 9380 posts
brian was faster, but here is another example file with 3 methods
one of them is pointcloud
one is just creating distance attribute to point for all points then sort by this attribute then keep first and connect to point
and the last is by using nearpoint() expression
- mickyblue
- 217 posts
- RepubliCommando
- 6 posts
- tamte
- 9380 posts
RepubliCommandoI'm surprised all of those still work, but also I have no recollection creating that file, so strange
This is a great thread and example @tamte but the example file I'm unable to replicate in H19 as this is using nodes that are outdated by many years. Anyone keen to take a shot at creating a new demo file to solve this?
here is another file with more methods, all use the same principle though
