Hi everyone. I'm Joe Drew, a programmer at Side Effects Software, and I was just as annoyed as you that Houdini didn't work in GNOME.
Well, I tracked down the bug and fixed it today. So, when a future version of Houdini Apprentice is released, you will be able to use whichever desktop you like.
Hope this is good news to some people!
Joe
Houdini and GNOME/Red Hat 8+
7027 8 0-
- Joe
- 483 posts
- JColdrick
- 4140 posts
Hi Joe - thanks for addressing this - I assume this was the crash whenever the standard Save/Discard/Cancel requestor came up? It's worth pointing out, however, that metacity(the default Gnome window manager in RH8/9) won't let you control much in the way of key equivs. The upshot is that you cannot let Houdini set keyframes in the channel editor with Alt-mouseclick because metacity grabs this combo. That would render it kinda useless, unfortunately.
I'm not sure if anyone found a workaround for this, but if they have - please post!
J.C.
J.C.
John Coldrick
- Joe
- 483 posts
JColdrickYes, that's the one!
It's worth pointing out, however, that metacity(the default Gnome window manager in RH8/9) won't let you control much in the way of key equivs. The upshot is that you cannot let Houdini set keyframes in the channel editor with Alt-mouseclick because metacity grabs this combo. That would render it kinda useless, unfortunately.Look in the “Windows” preferences. There you have the option of using Alt and “WIndows key” (at least) for grabbing the window and moving it.
- JColdrick
- 4140 posts
- ykcosmo
- 288 posts
- JColdrick
- 4140 posts
Yes I definitely want to test this at some point…good to hear you've had some success Cosmo, thanks. KDE is sort of my defacto standard ever since Gnome2 unfortunately, even though I was a hardcore Gnomer :evil: , and it was all because of metacity.
KDE has been pretty damn good since v3, so I'm not wanting.
If Fedora swings, we might consider it. Certainly not considering paying $$s for RHEE since all that money tends to go towards server sorta stuff that we don't need and their install is still terrible. If I were to spend money - it would be on SUSE. Latest version is pretty sweet - best startup and configuration I've ever seen on Linux.
J.C.
J.C.
John Coldrick
- Joe
- 483 posts
JColdrickYes, it definitely DOES allow you to do this!
Umm, but this still doesn't allow you to Alt-LMB to make keyframes does it?
I can't speak for Red Hat 8 specifically since I'm using Ximian Desktop 2, but when I set (using the “Windows” configuration dialogue) what key will move the window to the Super or Windows key, I can set keyframes using Alt+LMB.
This might require, though, that you turn off “Use Windows Keys” in the Key Bindings settings dialogue.
- JColdrick
- 4140 posts
- milagroman
- 16 posts
