nested string expression syntax
   10246   4   2
I'm trying to get two parts of this expression to evaluate, with no luck.
chs(“`opinputpath(”.“,0)`/del_face”)
The opinputpath evaluates correctly, but when I try to evaluate this by adding backticks around it:
`chs(“`opinputpath(”.“,0)`/del_face”)`
..it goes wonky. I've checked the docs on quoting and embedding expressions, but there didn't seem to be anything on nested evaluations.
After fumbling around a bit I stumbled on this solution:
`chs(strcat(opinputpath(“.”,0),“/del_face”))`
It evaluates just fine in as a string expression.
if you don't wanna mess with another nest this should work too
`chs(opinputpath(“.”,0)+“/del_face”)`
Jesse Erickson
Fx Animator
WDAS
Or for the terminally insane and to bring string concatenation to it's final end in an hscript expression, you could do this too:
`chs(opinputpath(“.”,0)+“/”+“d”+“e”+“l”+“_”+“f”+“a”+“c”+“e”)`
Thanks for the suggestion!
I was getting stuck on the nested functions, and thinking I needed to evaluate each one separately for some odd reason.
