playing with chops alittle… not sure what i`m doing wrong…
if some one can take a look and complete this motion and add little explanation it will be great …
thank you !
J.
Time shfit offset in Chops ... what i do wrong ?
4883 3 0-
- James_Burg
- 153 posts
- Pagefan
- 519 posts
Hi James,
on the chopnet1 -> geometry -> common tab, set the units to frames instead of seconds. Then on the channel tab but $NFRAMES in the end parameter,
or
put $TEND in the end parameter and leave everything as is.
In the current setup the units in CHOPS are measured in seconds. The data will be fetched at 0 till 10 seconds so only play the first 264 frames (Houdini starts counting at 0 in this case).
or
- James_Burg
- 153 posts
- Pagefan
- 519 posts
