i was wondering if you can have two metaballs with different shaders on each.
i tried attaching one shader (ie. blue) to one metaball, and attaching another shader (ie. red) to the other metaball. but when i render it, both of the metaballs are red.
is there a way so that one is red and one is blue?
Metaball and shaders
10669 7 1-
- Brownies
- 22 posts
- deecue
- 412 posts
You can do it through coloring each of the metaballs through the point sop. After merging, the colors will even mix correctly.
As far as an output goes..you can render at the merge sop and render through the open gl rop (either as shaded or wireframe). If you want to actually render through mantra, you will have to add a shader after the merge. In the diffuse of the shader (i used a vex layered), put Cr,Cg,Cb in the fields. Then render with mantra, and voila, colored metaballs.
As far as having different textured shaders on each of the metaballs, that might be tough. Don't have a solution for that one yet and don't know if there will be one.
Here's an example file, if you're interested..
http://studentpages.scad.edu/~dquiru20/metacolor.hip [studentpages.scad.edu]
Dave
Dave
Dave Quirus
- JColdrick
- 4140 posts
- MichaelC
- 344 posts
Check this out.
Metaballs with blended shaders
Metaballs with blended textures
Made an attribute for the metaballs and used it as a bias for a layered VOP shader. You can belnd as many as you want, but you have to daisy chain your networks in SOPs and VOPs to do it.
http://s91408461.onlinehome.us/meta.hipnc [s91408461.onlinehome.us]
I'm rendering an animation of the paint version. Will post it later.
- JColdrick
- 4140 posts
- deecue
- 412 posts
- MichaelC
- 344 posts
http://s91408461.onlinehome.us/junk/painty2.mov [s91408461.onlinehome.us]
Here's a quicktime. It seems to look best in this case if you use lots of larger metaballs with miniscule weights.
What can I say? It was a good idea and it has millions of uses
It''s like a whole new world of possibilities for shader creation has been opened to me.
You can really get crazy with this. You can use custom attributes to index shaders, you can blend them based on weight, and you can pass attributes back and forth with attribute transfer, modifiy attributes based on collision…
It's tons of fun to play with!
It''s like a whole new world of possibilities for shader creation has been opened to me.You can really get crazy with this. You can use custom attributes to index shaders, you can blend them based on weight, and you can pass attributes back and forth with attribute transfer, modifiy attributes based on collision…
- deecue
- 412 posts
here we go.. texture blends based off of the metaball fields. too bad you're limited to three metaballs with this method (just used the rgb channel data as reference for the blending)… still neat none the less.
Neat blobby stuff Michael. Pretty cool stuff. I'd love to see anything else you adventure in to with this method of texturing. Keep me updated.
Dave Quirus
