How to delete coplanar polygons ? [SOLVED]
   12694   4   2
After import from 3D warehouse a model, i have a lot of coplanar faces into.
Is there a way to delete these polygons ?
Thanks for replies
Edited by - March 22, 2011 14:38:45
You can triangulate them using the Facet SOP.
Thanks for your help Edward.
Triangulate with a Facet SOP ?
I can't find triangulate in FACET SOP, but in Divide SOP, there is a triangulate option. It's what you mean ?
But, i don't understand why triangulate faces ? Perhaps my bad english didn't explain what i'm looking for.
I have a 3d model with many faces with the same size at the same place. It's like i duplicate one model on himself and fuse together… A very bad model.
I can see, with display Faces numbers ON in viewport, many faces at the same place. (cf. attached screen capture)
So i have many faces with the same centroid, same number of points and same positions of these points, but how compare or group these faces ?
I have tried clean SOP, facet SOP, Divide SOP, Fuse SOP and i can't find something to do that.
Thanks in advance
Check out Ronen Tanchum's Remove Duplicates HDA on the Side Effects Exchange:
http://www.sidefx.com/index.php?option=com_wrapper&Itemid=137 [sidefx.com]
Btw, co-planar is just one of a few tests you need to make to find duplicate primitives.
Thanks a lot Jeff !
For those looking this digital asset,
on the Houdini Exchange:
Name: R_Remove Duplicates - Clean Up Duplicate Polygons
Author: Ronensart
It's exactly what i'm looking for.
Very long life to old school !!!
