Converting to Polygons?
11304 9 3-
- scscop
- 7 posts
- scscop
- 7 posts
- Erik_JE
- 300 posts
http://www.sidefx.com/docs/houdini11.0/io/ai [sidefx.com]
This is what i usually and do and then PolyExtrude it.
EDIT: Opensource software InkScape can export EPS if you don't have illustrator or is running linux.
Drive, monkey, drive!
- scscop
- 7 posts
- Erik_JE
- 300 posts
- tamte
- 9423 posts
- scscop
- 7 posts
just tried saving as an older format and still nothing.
And the Trace is what I'm trying to get around. Im filling this text with particles to explode outwards but when I use a tiff with an alpha, trace, and extrude for 3D text, the particles are only being placed on the extruded sides only and not on the traced front and back
- scscop
- 7 posts
- tamte
- 9423 posts
you can try append divide sop after your extrude , then measure (area) then in Source POP set Emission Type to Surfaces Attribute
then if you still have problem with particles not generating from front/back faces, post sample file (don't forget to lock input geometry/curves) and we will look at it
- grayOlorin
- 1808 posts
