hserver.exe Integer Division by zero error
   14730   12   0
when I installed Houdini Apprentice Edition, right before the install finished a dialog box came up saying Integer Division by zero error. and when i try to start any of the programs I get a no licince server error. but when I open licencse admin It says I have a valid licence and the server is running?
I'm running it on WinXP pro SP1 and trying to run H5.5.151
Please start the License Administrator & go to View -> Diagnostic Information…
Please save the information & post it here. That will help in determining the problem.
Cheers!
steven
Diagnostic Output
If you are having licensing problems, please save this information and email it
to support@sidefx.com.
License Administrator output
Generated on Wed Nov 06 114941 2002
Local host name BRYANTA
Local server code f0875885
Local ip address 137.112.137.210
License server name bryanta
License server server code f0875885
Server ip address 137.112.137.210
License server is running Yes
Has SERVER license Yes
License server version 5.5.151
May modify server from this machine Yes
License Administrator version 5.5.151
Http proxy host (none)
Using standalong mode No
Can retrieve http//license.sidefx.com/index.php Yes
Installed licenses
LicID Platform Product Ver Avail Expiry
6494a1fd Generic Houdini-Master-NonCommercial 5.5 1/1 06-dec-2002
02f97bf1 Generic Render-NonCommercial 5.5 1/1 06-dec-2002
sesictrl -i output
—– SERVER bryanta ——–
Lic 6494a1fd 1 “Houdini-Master-NonCommercial 5.5” Generic 06-dec-2002 +.+.+.+
1 licenses free
Lic 02f97bf1 1 “Render-NonCommercial 5.5” Generic 06-dec-2002 +.+.+.+
1 licenses free
hserver -l output
licenses file
## Side Effects Software License File
# For license information, please contact
# Side Effects Software Inc.
# 477 Richmond St. West, Suite 1001
# Toronto, Ontario, Canada
# M5V 3E7
# licensemanager@sidefx.com
# http//www.sidefx.com
# NOTE This file may be modified by the licensee
# Key installed 223042 11/05/02
SERVER bryanta f0875885 bf0c4cb1901ed6809cfb79da8662549464d66b6649d34
# Key installed 223044 11/05/02
LICENSE Generic Houdini-Master-NonCommercial 5.5 1 06-dec-2002 +.+.+.+ \
bryanta 6494a1fd e3255e13a67c08a4bfe306633d182407263a2f3b3dd7b
# Key installed 223046 11/05/02
LICENSE Generic Render-NonCommercial 5.5 1 06-dec-2002 +.+.+.+ bryanta \
02f97bf1 28afd779dfd3d2830d87bff6b7963478723fd60842ddf
I did not get this licence automaticly I whent to the website to get it.
The error says “License ErrorUnable to connect to hserver for license acquision”
Please start the License Administrator, go to File -> “Change License Server…” & check the “Use Standalone Mode” button.
You might have to wait a short while before you can click OK.
Once done, start Houdini
Please let me know how it goes.
Cheers!
steven
doing this requiered me to reboot so here is the excat error that came up“
”The exception Integer division by zero(0xc0000094) occured in the application at location 0x00440b6b“
trying to open houdini still results in a error
”License ErrorUnable to connect to hserver for license acquision“
here is the diagnostic info after changeing to stand alone mode
Diagnostic Output
Generated on Thu Nov 07 000912 2002
Local ip address 127.0.0.1
Server ip address 127.0.0.1
Using standalong mode Yes
Installed licenses
sesictrl -i output
Lic 6494a1fd 1 ”Houdini-Master-NonCommercial 5.5“ Generic 06-dec-2002 +.+.+.+
1 licenses free
Lic 02f97bf1 1 ”Render-NonCommercial 5.5" Generic 06-dec-2002 +.+.+.+
1 licenses free
hserver -l output
licenses file
# M5V 3E7
Please go to the Control Panel -> Administrative Tools -> Services.
In the Services dialog window, please look for Houdini License Client & if it's not started, please right-click on it & select Start.
Also, please note the “Startup Type” value. If it's “Manual”, please right-click & select Properties. In the Properties dialog, please change the “Startup Type” to “Automatic”.
Cheers!
steven
It is set to start automaticly,but is not currently running, and when I start it again manualy it still crashes giving the error
“The exception Integer division by zero(0xc0000094) occured in the application at location 0x00440b6b”
I would have to recommend you re-install Houdini.
Cheers!
steven
I have already tried twice both times resulted in the integer div by zero error right before the install finished.
I downloaded it again, reinstalled and still had the same problem.
Perhaps this link [sidefx.com] can help you?
Also, are you logged in as an Administrator when installing Houdini?
Cheers!
steven
I am logged in as a privialged user. And the install finishes fine it's just that hserver keeps crashing
I think the issue is something with my other software. I have recently installed a new version of the .NET Framework. Does hserver interact with that at all?
Do you mind re-installing Houdini as an Administrator?
No, hserver does not interact with the .NET framework.
Cheers!
steven
by privilaged user i meant I was using an acount with Administrator set. sorry i was unclear about that.
