how to group just connected pieces?
   14468   10   2
Hi there,
Is there a way to just group connected primitives with the boundingbox methode? So only those primitives will be selected whos connected members are all in the boundning box.
HI
I'd give VOP a try with neighbours VOP and “add to group VOP” maybe .. then convert point group into primitive group in SOP.
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
Not exactly, but this will work:
- connectivity SOP
- partition SOP - Group A (group_$CLASS )
- group SOP, bounding box - Group B
- group SOP, boolean of Group A and B = Final Group
Sean Lewkiw
Machine FX - Cinesite MTL
Thanks for your advice sum][one. I will give it a try!
Mr Catfish I tryed to go your way but I dont get it. please show me the problem. enclosed a test hip file.
And big thanks for your nice apple!
grp Test.hipnc (99.8 KB)
Hm, you're right, that doesn't really work. Try this instead.
grp_test_480.hipnc (127.9 KB)
Sean Lewkiw
nevermind my first post too .. for some reason I thought it was something I've done already in VOP! .. I didn't find a solution by following that route yet but I'm still trying
glad mrCatFish came out with a working one!
JcN
Thanks Sean!!!
but the “common group” doesent really ignore prims. It becomes more visible with fewer shattered pieces…the group should just select whole pieces.
here is a working example
primgroupmask() is your friend
scrub the timeline to see the effect
select_pieces_by_boundary_object.hipnc (113.3 KB)
Thanks Tamte!!!,
Works great!
But I dont' really understand how primgroupmask works.
!* `primgroupmask(”../Whole_Pieces_inside_selection“, chs(”../group_mask“))`
Any comment would be nice!
primgroupmask() will list all primitive groups on the geometry which match the given mask, in this case “piece_*”
and because ../Whole_Pieces_inside_selection node contains only groups that are inside the bounding objects you can just get them all
!* is there to by default select nothing, because if no whole piece is inside the bounding object then by default primgroupmask() will result in empty string and that would select all primitives so !* in front will prevent this
at first I did this without intermediate attribute “__group” directly in combine tab of group sop and it worked correctly, but as soon as i animated bounding object, it was not updating, even though all was time dependent, but it works this way
Big thanks!!!
