how may i interupt/kill a render sent from hscript without closing it?
if i'm rendering to mplay, i can just use the esc hotkey to kill it which gets sent back to hscript, but what if i am rendering to file (or a series of files)?
i realize that break will pause the rendering and ctrl-break will close hscript all together, but i want to be able to kill it without closing hscript (so i can resave file, make param adjustments, send off another render, etc)…
running windows, 6.1.208..
thanks,
dave
kill render in hscript without closing
6110 6 0-
- deecue
- 412 posts
- stevenong
- 1634 posts
- deecue
- 412 posts
- mark
- 2675 posts
deecue
thanks,
dave
If you're rendering a single frame in the background, you can use the hscript commands “rps” and “rkill”. Type
hscript-> help rps
hscript-> help rkill
- deecue
- 412 posts
- woody
- 7 posts
I've found that you can use the Task Manager in windows to kill a render sequence. Ctl-Alt_del , choose task Manager, go to the processes tab, find the mantra process, and End Task. One problem is there's no way to identify the rener process in the Task Manager, so if you have more than one render going and only want to kill one, you're out of luck.
- deecue
- 412 posts
this is true… i can kill it there..i actually like the ctrl-shift-esc method…(many people don't seem to know about that one) :wink:
it becomes an issue sometimes because it keeps running another mantra for every frame and takes a good number of times to catch up with it for faster renders.. and also doesn't work out for multi-host rendering (atleast i would not think).. or like you said, multiple renders at once. but is still an option..
would be kinda nice to stop it in hscript somehow kind of like how houdini has the interupt button when rendering…
thanks
thanks
Dave Quirus
