houdini on mandrake
   5080   3   1
I installed mandrake 9.2.
I run ./houdini.install, it said:
./houdini.install : line 681: exec: xterm: not found
so it can't be installed…
what is the problem?
^_^
When I installed Houdini on my Gentoo Linux box I got the same error.
I don't know if this will work for you but here's what I did…..
I opened that houdini.install file in my favorite text editor and jumped to line 681 and remove the word exec on that line. I saved the file and ran setup and houdini installed fine.
If you don't feel like editing to file, maybe try switching to a tshell or Cshell before running setup. I don't know if changing shells will work but it's worth a try
Hope this helps,
/R
/Rick
Hey ykcosmo
maybe this helps
http://www.sidefx.com/forum/viewtopic.php?t=331&highlight=xterm [sidefx.com]
I can start to install houdini now ,with xterm installed,but there comes another problem:
./houdini.install: line 653: [: 37%: integer expression expected expr: non-numeric argument
warning : not enough space on /opt/hfs6.1.309.
but I have 1.8G left in /opt/….what is the problem?
^_^
