Controlling RBD Interaction
3256 2 2-
- NFX
- 183 posts
So recently I have been trying to learn RBDs and am creating an animation where a rock with movement that I hand animate rises up through the compressed soil-like ground. However when my rock touches the ground layer it results in a more explosive behavior then anticipated. It almost seems like it is snapping the ground open and sending chunks flying. I was wondering if there is a way to control how explosive RBD interactions are or at least to dampen the effect realistically?
- goldleaf
- 4259 posts
- rafaels
- 702 posts
I think the split impulse parameter on the RBD solver (supposing you're using bullet) does the trick…
Cheers
Cheers
Toronto - ON
