Reloading density maps on fur
   3829   5   1
Im painting some density/ length maps for use on a fur object, but as when I resave the map out of photoshop I cant get houdini to reload the new version of the map. I end up having to save the map to a different filename (not good!!)
Any hints?
It seems going to the render menu and choosing ‘Reload Textures’, then changing the map to another file then changing it back works. A bit of a clunky workaround though
The way round this is to have the file read in as normal. To see the results you need to render the image so what you do is add a script to the pre render ie this Hscript
opparm -c /obj/mynode/some_othernode/myfiles reload
In this example I am telling the rop to run the reload parameter in node blah blah. This way at render time your file will read the updated one.
Rob
Gone fishing
hi!
also you can try texcache -c in a hscript textport
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
texcache -c dosent work
and im not even rendering, just viewing in the viewport for now.
Running the opparm command:
opparm /obj/LogUpper_fur/lengthmap reload
in the texport results in this:
Can't find node /obj/LogUpper_fur/lengthmap
Sounds like a bug. Submit it.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=25347 [sidefx.com]
