Truncated Tetrahedron
   4847   7   1
Someone create one of these, and well I'll be impressed, can't see a ‘houdini way’ to do it. http://en.wikipedia.org/wiki/Truncated_tetrahedron [en.wikipedia.org]
Turns out you use an add sop and manually specify the points, than polygons.
hi,
Place a platonic solid and connect a polybevel with All Points as default entity.
Cheers
Toronto - ON
I managed to achieve what i want by permutating some Cartesian coordinates, the reason is because I want it to be as light as possible. I'm creating the Archimedian solids, than going on to the Johnson solids, which means there will be a lot of nodes in my networks. Thanks though.
Cool, I wouldn't mind seeing your results!
Cheers
Toronto - ON
Accidentally Overwrote the file! So now I'm going to start again, I'm working on other stuff so maybe in a week I'll get round to doing it. I'll post an OTL
Delight0092
Accidentally Overwrote the file! So now I'm going to start again, …
there is Backup folder next to your hip with many previous save versions, so usually you can recover your overwritten file
Out of idioticness I set my save to overwrite.
