OpenGl render node - bug?
   3598   4   1
when I use the OpenGL-ROP for rendering, all the result are wireframe and with some decorations (point numbers).
I tried different settings for shading mode and gl rendered… Makes no difference. Always wireframe with point numbers.
Is there a option, I am not aware or is this just a plain bug?
H12.1.134 + build 138
Point numbers are still present in ogl render.
It seems the rest is working now…
Can anybody confirm this?
Have you done a “Save as Default” in the 3D viewport display options while point numbers were on? The OpenGL ROP should be changed to ignore all decorations, but I suspect this may be what is happening in your case.
You can remove the defaults by deleting display.pref in $HOME/houdini12.1, or by saving a new set of defaults through the Display Options dialog.
Thanks twod, for your suggestion.
It was even simpler. I just got feedback from support.
The scene renderer was set to H11. When I change the setting to one of the ogl modes, the error does not appear. With H11 it remains but I can live with that.
Cheers
the flip tank are wairframe why ??
this is unusually
