Select and Renderman
   8478   3   1
Does Select support the RenderMan? The main website says that it will export RIB, but does it support RenderMan in its entirety? Say, is it the same level of support as in Master?
Hi David,
Houdini Select does not support PRman.
Cheers!
steven
Does that mean I need to use Master or Escape to have the compatibility with Renderman. BTW, not using PRMan, but using AIR.
Hi David,
As it stands, you need to use Houdini Master for PRman support only.
Cheers!
steven
