Microsoft Visual C++ Error
   7612   7   0
Hello everyone,
I have a strange error when I try to start Houdini, an error window appears with this message :
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Program Files\…
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
Last Thursday everything worked perfectly, I'm on the apprentice version, but now I can't even launch the program.
I tried to update my windows 7, uninstall and reinstall houdini but the error is still there, the window even pop up during the installation.
Does any of you has a suggestion ?
Thank you
Did Windows automatically install new updates, or did your graphics driver automatically update itself?
I manually installed new windows update, but after the problem first occurred. And as far as I know I did not touch my graphics driver just before having the problem.
Could a reinstallation of the graphics driver solve the issue ?
So I tried to reinstall the driver, nothing changed.
Also I receive a problem signature when the app crash :
Signature du problème :
Nom d’événement de problème: APPCRASH
Nom de l’application: houdinifx.exe
Version de l’application: 12.5.0.316
Horodatage de l’application: 5140e80f
Nom du module par défaut: MSVCR90.dll
Version du module par défaut: 9.0.30729.6161
Horodateur du module par défaut: 4dace4e7
Code de l’exception: 40000015
Décalage de l’exception: 0000000000042686
Version du système: 6.1.7601.2.1.0.256.1
Identificateur de paramètres régionaux: 2060
Information supplémentaire n° 1: bb33
Information supplémentaire n° 2: bb33a86ad835fb5d52f50b0336985503
Information supplémentaire n° 3: 13c3
Information supplémentaire n° 4: 13c3baeb5a65df6ee766b4f95dc07811
If it helps.
i had similar issues few years ago. windows crashing most 64bit software.
only solution i found was reinstall of the whole OS.
in the end i figured out it was my ssd drive.
usually it happen after windows made a checkdisk
on launch and tried repairing something.
your problem might be differnt. not sure. but i remember it also was telling me about MSVCR90.dll..
I don't think you need to reinstall Windows if it was working fine already? Is this 32-bit or 64-bit Windows?
Hi there,
I manage to solve the problem, the issue was with environment variable. I had HOUDINI_OGL_SOFTWARE = 1 and HOUDINI_UI_QUEUE_SIZE active at the same time and it made the application crash.
Now I only use HOUDINI_OGL_SOFTWARE = 1 because I have the
NT_GeneratorThread::queueEvent event queue full. Event dropped.
error.
But the error keeps happening when I render, it's painful when I have to render 240 frames and I have the surprise to see the problem after 50 frames.
I'm on a windows 7 64bit.
I wouldn't expect those environment variables to interact. It's probably more likely due to the fact that you have HOUDINI_OGL_SOFTWARE=1.
