Flip colliding with another cached Flip
   5742   4   1
Hi there,
Im trying to use one Flip sim as collision object in another Flip sim.
So I use Surface field of first sim, as Collision field in second sim.
It kind of works, but a lot of particles still go through it. I can display Collision field in second sim, looks correct. Maybe I should apply it in a different way, inside solver ? Im not so familiar with Gas micro solvers….
Attached HIP and screengrab to get the idea what have I done.
thanks!
splash1.hipnc (1.5 MB)
Michal Tas Maciejewski @ www.vfxtricks.com
Your file is very close, just a couple of tweaks:
1) The Particle collision method only collides with other DOP Objects, not collisions brought in via SourceVolume, which directly manipulates the collision field. You need to use MoveOutsideCollision in this case.
2) Your SourceVolume DOP will solve twice per frame since you have the FLIP substeps to 2, but the original sim is only outputting data once per frame. So you're not getting properly interpolated data out of the first simulation for any sub-frames, which degrades the collision quality.
You could substep the entire DOPnet on the first FLIP sim and cache out the half-frames. Or just interpolate the output volumes from the first sim as that's probably good enough for collisions.
The attached takes the second approach, using a WhitewaterSource node to handle the interpolation, as it's already set up to handle that in case you want to substep a Whitewater sim. It also rebuilds the surface SDF within a small distance to help ensure good collisions in the second sim.
splash1_wwsource.hipnc (1.5 MB)
Thank you so much. Im glad i can avoid Micro solvers for now.
Yes, I always forget to check if substeps are matching. Cool trick with new whitewater source node. I already looked into it to see accel/curv emission.
Works like a charm
cheers
tas3d
Works like a charm
cheers
Noticed that your hip file was NC. Can you talk about your plans for Houdini fluids at Scanline, if any?
oh, im just playing with H at home, recreating some workflows that we use in 3ds.
Scanline is definitely not interested in using H.
