ZLIB_1.2.3.4 not found
   8753   5   1
i'm using Manjaro 64Bits (Arch Linux fork) and i have this error when i want to show help or export a preview in mp4.
./hbrowser-bin: /opt/hfs12.1.230/python/lib/libz.so.1: version `ZLIB_1.2.3.4' not found (required by /usr/lib/libpng16.so.16)
Any help would be great
Same problem here :x
You can for now manually paste the resulting help url into a browser, manually xdg-open it, or use elinks as your help browser (enforced via environment variables), since elinks does not seem to be affected by the zlib issue.
Martin Winkler
What about 12.5?
edward
What about 12.5?
Same problem. (Tested in demo mode)
This problem can be solved by deleting libz.so.1 from /opt/hfs.xx.xx.xxx/python/lib. Make sure to backup the file in case something goes wrong.
Nir Zarkovian
Thanks for this trick.
