displacement shader not working
3147 2 1-
- kahuna031
- 897 posts
- rafaels
- 700 posts
It did work for me but only when I used that “Displacement Shader” parameter you exposed on the geometry obj.
I also tested creating a new geo container and object merging the geo from the first container and then applying your shader in the material slot and it worked fine. My guess is that by adding the “displacement shader” rendering parameter you bypass the material displacement capability.
Cheers
Cheers
Toronto - ON
- kahuna031
- 897 posts
