"Advect by Volume" position advection in DOP POPs?
   15709   6   1
First of all, I'm experimenting on “bleeding edge” territory for quite a while now – using the “hidden” DOP POP nodes (popsource, popintegrator, etc) which were present in beta versions but are now hidden.
(The reason for this is that in terms of speed they _rock_. I don't want to get into details but I'm a much happier person now with all CPU cores working on particles )
Okay, so with that being said, I could replicate most POP stuff I wanted, but I'm not much of an expert of the advanced details of microsolvers and such, and the functionality I'm needing right now is _position_ advection of these particles.
I have some particles and a pyro simulation, and I want to use the pyro's velocity field so it would only advect particle positions (but without changing anything else on the particles).
I can advect using a fluid force, fine, but that uses a “force”-type advection which is not the effect I'm looking for. I tried the Gas Advect microsolver (not sure if I managed to set it up right, though), even tried to build a Geometry VOP DOP, but to no avail. (Any of these can be a solution though, as I could easily messed up their settings.)
Any ideas on how to achieve this?
cheers,
imre
Imre Tuske
FX Supervisor | Senior FXTD @ Weta FX
qLib -- Houdini asset library
http://qlab.github.io/qLib/ [qlab.github.io]
https://www.facebook.com/qLibHoudini [www.facebook.com]
riviera
I'd recommend looking at the internals of the Whitewater solver, which is the biggest user of the Pops-in-Dops toolset in 12.5. It advects the foam and bubble particles by the FLIP velocity field, basically using advection just to calculate an accurate “advection velocity” and adding it to the “targetv” of the particles.
It's a little more complicated in Whitewater, as it uses the velocity from the previous and current timestep to do midpoint advection in time, which is more accurate for things like foam, but probably unnecessary for advection by a Pyro sim. In that case you can directly use GasAdvect's ability to update a temporary velocity attribute only (not position), then add that temporary velocity into the particle's targetv with an airresist value controlling how strong the advection should be.
All these techniques are used within Whitewater.
Thanks for the tip, I managed to get it working eventually
The trick was to add the Fetch Data OP under the POP Object (and I kept trying to attach it near the gasadvect DOP, hence my frustrations and warnings of “unexpected subdata ‘vel’.”)
To have some advection outside the container, I set the pyro border type to Streak (pyro->Initial Data->Border Type).
What was misleading for me is I looked really hard in the whitewater solver, but not much in the whitewater _object_, which contained the velocity field attachment. DOPs can be “here be dragons” land for me sometimes…
cheers,
imre
Imre Tuske
Hey,
Old post but thanks for the tips, works like a charm
Steve
Steven Dupuy
Freelancer
riviera
Sorry if I'm going offtopic, but what is the difference between the different border types? It's something I've wondered for a while, even after reading the docs I don't fully understand.
riviera
imre
In the whitewater solver they sample the vel field as a force to then do the integration with the powerful geometry vop dop hiden node.
I'm very courious about this node in H13, because all pop's finally will have a force integrator written with dops toolbox(H12.5) or HDK, we will see.
alejandro
riviera
imre
I can't imagine it being much different than the existing Gas Integrator dop, you have plenty of options in that to begin with.
