Hey all,
Im just wondering how you can get an empty pop solver in Houdini 13? Im not finding the one Im familiar with that was in Houdini 12, any suggestions?
Thanks all
S
POPSolvers in Houdini 13
8726 6 3-
- dilatedpixel
- 11 posts
- Sadjad Rabiee
- 1391 posts
- dilatedpixel
- 11 posts
- fsimerey
- 279 posts
I think you could watch this new tutorial from Side FX about new particles system in H13.
http://www.sidefx.com/index.php?option=com_content&task=view&id=2631&Itemid=166 [sidefx.com]
- dilatedpixel
- 11 posts
- Ian Webb
- 1 posts
This is a bit old, but I had the same problem. Given the number of tutorials out there, “just use the new system” doesn't sound like much of a solution to me.
After some digging around I found you can create an old style popsolver in 13 if you need one with some Python or Hscript. Here's a Python snippet:
hou.node(hou.ui.selectNode()).createNode(“popsolver”, exact_type_name=True).moveToGoodPosition()
The key is exact_type_name, as the default new solver is called popsolver::2.0.
- tamte
- 9415 posts
you can do that without scripting
if you turn on Operator Type Manager/Operator Type Bar to Display Menu of All Definitions
(which is helpful to keep on anyway)
it will show a little bar on top of the properties pane with node type and library dropdown boxes
you can just place POP Solver and then from the type bar saying popsolver::2 choose popsolver to switch it to previous version definition
