Try to use point cloud to add color
   4589   2   1
I am trying to use some points with color as point clouds to add some color to my surface so I am using pcopen SHOP to try sampling those colors but I am not getting it to work.
In the sample file I am trying to sample the color from a circle points and add to the diffuse color through a pcfilter inside shops but I don know what I am doing wrong.
In Peter Quint's video about point clouds it seems to work nicely.
Can anyone help me with that?
Thanks.
pc_try_001.hipnc (1.2 MB)
https://vimeo.com/user2163076 [vimeo.com]
Hey,
Save your point cloud to disk as a .pc file and it'll work. Also when you test it out, make sure to adjust your radius (0.8) worked nicely for me.
The trick here is that the op: expression doesn't evaluate in the shader context, you need to explicitly point to a file in disk.
Cheers
pc_try_001_478.hipnc.zip (100.7 KB)
Toronto - ON
Nice! Thanks for the info!
